vjswhippet's avatar
vjswhippet
RV Kwik Step Not coming IN
So now what ? Is there a way to retract the step manually ?
  • That wire is NOT connected to anything. It is for the OEM optional wall switch control for the step light. Odds are the motor has a dead spot. Open and close the door with the engine running. IF the under amber step light goes ON and OFF when opening and closing the door. the wiring and control are OK, You have a bad motor. Doug
  • DFord wrote:
    More info needed to give a good answer. Does the step try to move at all? Can you hear the motor trying to move the step?
    Push comes to shove, you'll need to get under the step and remove the cotter key on the linkage so the step will move and then push it in and tie them up with a rope or bungie cord.
    it's not doing anything. I'm wondering .... we found a lose wire thinking it was to the under the step light that did not work. That didn't fix the light, nor trying a new bulb. Could it be that wire didn't go to the light and has overridden something? When hubby gets home he'll undo that wire since it worked before we connected it ?
  • More info needed to give a good answer. Does the step try to move at all? Can you hear the motor trying to move the step?
Having RV issues? Connect with others who have been in your shoes.24,245 PostsLatest Activity: May 12, 2025
