TechWriter wrote:
CA Traveler wrote:
mchero wrote:
I'm considering 4 250W panels on the roof, 3 across the top of the bedroom and the 4th between AC 1 & 2. Morningstar MPPT-60 charge controller.
Still on the fence regarding tilting panels. Also leaning toward parallel connecting rather than series.
The MPPT 60 is rated at 800W for 12V. It might handle 1000W and derate to 60A but check with MS before connecting 4 panels. If it's OK and your panels are flat then you likely be under 800W most of the time anyway.
4 250W panels implies that you will exceed the 150V input limit with a series connection and this is a big no no. A series/parallel connection will work.
In summary: 3 panels at 750W will be OK provided your panels don't exceed 150V in series. For 4 panels you need to do some homework or convert to a 24V system which will handle 1600W.
Instead of Morningstar, check out a MidNite Solar Classic controller. You'll have more options with a Classic.
There are several versions rated from 80 - 96A (Morningstar = 60A) and 160 - 200V (Morningstar = 150V).
MidNite also has a online sizing tool.
Good pint Techwriter! hmmm, will start looking over your links. Thanks!
