mena661 wrote:
mchero wrote:
Once I have decided on a particular panel I then need to decide parallel or serial connecting the panels. The shade issue with serial connected panels worry me plus I'm being told the Morningstar 60AMP MPPT charge controller "might" not be enough.
1000W will get you somewhere around 70 amps in southwest, clear sky, summer sun. In most circumstances, IMO, you'll be just under the Morningstars 60A limit. MPPT controllers will clip amps but why waste everything over 60A? You're probably looking at an Outback 80A or a Midnite Solar 150 (95A). Both controllers are around $700 each. What reading did the hydrometer give?
Was getting 1275 on all cells
