I;m going to reroute the galley tank discharge to the black and grey water discharge pipe. Is the rv black pipe the same as Home Depot white pipe? If not, where can I get the black pipe?
They are the same size. Last Spring I had to replace the p-trap under the bathroom sink. It was the same size as the white p-traps used in your home. You can use the white.
Having RV issues? Connect with others who have been in your shoes.24,406 PostsLatest Activity: Aug 14, 2026
