Erie Tom wrote:
kellertx5er wrote:
Erie Tom wrote:
People do not turn off the breakers when leaving. Bad for the breaker ...
And just what basis do you have for this claim? The only thing a breaker cares about is how many amps are flowing, at how many volts and how hot is it where it is.
I do agree it is good practice to turn the breaker off before plugging in to prevent arcing of the plug contacts.
Contacts get worn and spread apart. causing it to jump.. It is not a smooth contact... Basically plug is gone south because of use. Simple!!!!!
A little added information
f you give your recreational vehicle's breaker a break in certain situations, you'll help keep your RV's electrical system in top working condition.
That advice comes from Jim Finch, KOA's assistant vice president/technical services. "There are three times that the campers should turn off the breaker in the campground electrical supply equipment,” he says.
Those circumstances are:
Before you plug your RV into a campground’s power pedestal
Before you unplug your RV from a pedestal
And when an electrical storm is building in the area.
Here is why you should turn off the breaker in the first two situations:
“If there's anything inside the RV that is on – if everything were turned off, it wouldn't matter -- in the process of plugging it in and unplugging it, you can get a situation where it can arc across, and it isn't totally safe,” Finch says.
“I suspect that if you got an arc, it could damage whatever was turned on in the RV, too,” he says, adding that the caution especially applies to 50-amp rigs. And, if lightning is on its way, it’s a good precaution to turn off the breaker and then disconnect your RV from the campground’s electrical system, Finch says.
“If there's an electrical strike at a transformer or in the supply side of the power company's equipment – and that does happen – it can travel down the lines and burn up equipment in the RV,” he says.
Once the thunderstorm has passed, reverse the order of reconnecting your electricity:
Plug in at the power pedestal.
Then turn the breaker back on.
“It's just a matter of safety. I know we've had electrical strikes on a transformer inside an RV park. Unlike a normal transformer that maybe supplies two or three houses, a transformer inside an RV park covers dozens of RV,” Finch says.
And, lightning doesn’t necessary have to strike in the park itself to cause harm.
“If it's close enough to transmit down the line and create a power surge,” an RV’s system could be damaged, he says. An RV owner turning off the breaker, then disconnecting the rig at the power pedestal has taken similar precautions to putting a surge protector between a wall outlet and a computer.
