was_butnotnow's avatar
Jan 23, 2018
RV Ranges
Looking to replace my Atwood RA 2133 range but looking online seeing they came in 21 or 22 inch. The 22 modules seem to have the same specs as the 21 in ones. H 21 3/4 W 20 5/8 What is the difference? Or what am I missing? Don't want to order the wrong size as these things are not in any story but must be shipped.
My stove opening measures W 21 H 21 3/4 top of grate 22"
  • rhagfo's avatar
    rhagfo
    Explorer III
    We replaced the original Range in our 2005 Copper Canyon 32' 5er just before retiring. This is the Atwood Range 21" we bought. This unit is a sealed top, there isn't an opening around the burner heads to let spills or splatters fall through, makes cleaning much easier. The burner heads are like a residential stove and give better heat. The oven works well once we installed a pizza stone.
    DW LOVES to cook and this unit gets a workout. I did need to shim the sides of the opening to install it.
    We bought through PPL Motor homes and great price and service.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    The Specs as far as Burners are the same. The only thing you are missing is 1"
    Grap ye old tape measure and measure. Then look at the specs and see which one fits the hole. That simple.. NOTE.. Appplies to TV upgrades too. I measured the WIDTH of the opening (I knew it would be shorter due to the change in aspect rations) and the Pawn Shop had one EXACTLY the same width. I'm watching it now. Did some woodwork and a piece of trim and you'd swear the factory put it there.
  • is the depth the same? could be a mistake on the web site. i’d give them a call
Having RV issues? Connect with others who have been in your shoes.24,373 PostsLatest Activity: Apr 02, 2026
