I have a 2007 Winnebago Voyage It has a triple Kwikee step. The motor that it uses is a 214 1001> I ordered one through Amazon and the Motor Matched exactly except one thing. The shaft on the new mo...
When you swap the Gear from the old motor shaft to the new motor. There IS a washer that is installed FIRST that will make the shaft the correct length. IF you have NO washer, then you lost it. Doug
