JBarca's avatar
JBarca
Nomad II
Oct 06, 2022
RV style AC attic duct work - what is it called, brand etc
I restore older campers and there are times the AC ducts in the attic gets damaged beyond using thick HVAC tape to seal the air leak, the whole duct needs to be replaced.
I am trying to track down who makes them, or at least what they are called in the RV industry in attempts to buy some.
Here are pics of what I am talking about. This size has to fit through the rafters.
The ceiling registers are the older standard round turn type to adjust air flow. I know where to buy them.
This is the attic with the roof off showing the AC ducting I'm trying to locate.
The cieling air box on a older Dometic AC unit
Curved ducts come out of the air box and head down the camper through the rafters
A close up of the space the duct fits through the rafter. You can see the white round ceiling register poking out of the ceiling board into the duct
Thanks for any leads on this.
John
  • I think that they are made of foam board. They are cut to size for what is needed and taped together. Most any foam board will work but the aluminium faced is the best choice. If the big box building supply stores do not have the thinner foam board any HVAC supply will.
Having RV issues? Connect with others who have been in your shoes.24,204 PostsLatest Activity: Feb 22, 2025
