spacebetty
May 19, 2015Explorer
Thanks for that, BFL13!
I have several new questions :/ Should've known this wouldn't be as easy as all that!
So what I thought was the ground wire was attached to a bolt on the underside of a trailer rail, and that whole assembly was just a mess of rust. I started cleaning it up but it was too far gone, so I thought I'd take it off, get a replacement bolt/nut, replace the ring connector, and possibly grind down the area around the hole in the frame (is that necessary? wire brush doesn't do much good). But I can't get the nut all the way off...
It would be no problem if I could get better leverage on top; the head of that bolt is a flathead and it's rusted away enough that the edges are a bit rounded, and I only have space to use one of those little horizontal ratchet drivers...
So, is it a bad idea for any reason to extend the wire a bit and connect that ground to my battery? The other option sounds like hard work, esp without access to a lift... I don't even know if I'd want to use a grinder in a space that constricted/position that awkward.
Oh, also, everything (incl. everything inside the trailer) is still working exactly how it had been before I started loosening that connection - could it still be acting like a poor ground even in that position (and coated with WD40)? Or does that mean this isn't even the ground wire for the running lights? I mean, clearly it needs to be fixed regardless.
Would there be a ground for the running lights on the truck as well as the trailer, or only on one or the other?
A few years back when I had the hitch wiring installed on my truck, they replaced the trailer cord as well, so that wiring is also newer.
Having RV issues? Connect with others who have been in your shoes.24,414 PostsLatest Activity: Sep 21, 2026
