Chandalen's avatar
Chandalen
RV Voltages too high while charging
I have a problem and have been wrapping my head around this for a few days.
I have four 100w Solar panels, and a Morningstar RJ-45 programmable charge controller wired to batteries. I have Four Interstate golf cart batteries in serial/parallel to make a 12v bank.
I have a Pure sine 2k inverter wired to batteries with two 1/0 wires per pole, and fused @150 amps per positive line.
My (major) problem is the Absorption phase of charging is at 15.3 volts.
This changes the RV wide battery powered voltage to 15.3 +- volts. This is really high for the LED lights I have, and I am afraid they are going to start burning out.
Because the absorption voltage is 15.3, the inverter turns off. Its voltage threshold is 10-15v.
For now, I dialed down the absorption voltage to 14.9 and everything is working. I am aware that my batteries will not fully charge with that voltage as its 0.50 less than needed. I was planning on equalizing once a month, when I'm not using the camper, as that voltage is 15.6
I can’t imagine I am the only one who has run across this issue, so is there an inexpensive fix, that won’t waste valuable battery power?
I have a small (1 amp) voltage stabilizer for a battery venting fan that can tolerate no more than 14v (which I found out the hard way) that works well for the fan.
I know that the DC items in campers can tolerate 11-15ish volts, I’m just wondering how well and for how long that fridge can run on 14.9v while the batteries are topping off, and the inverter is useless if I cant run it when the batteries are topping off either!!
I appreciate any feedback and insight!!
-James
