Gjac
Dec 13, 2013Explorer III
westend wrote:My MH came with a screen that would slide over the open window to keep bugs out. I removed it years ago but thought about using the screen as a template and cutting and installing Plexiglas or Lexan storm windows, that would use the same track as the screen. My other thought was to paint the outside frame with a rubber material like the truck bed-liner to insulate the frame.
If you could make a removable storm window, you'd be set. The way I see most of them built, it may be easier to make an insert to fit the inside.
Having RV issues? Connect with others who have been in your shoes.24,383 PostsLatest Activity: Apr 25, 2026
