D.E.Bishop wrote:
While I am probably opening a huge can of worms here, I would like to clear up a few things if possible.
The NEC is really a product of the NFPA.
The NEC or the Code is the National Electrical Code, it is neither a CODE(law or rule) nor is it National. In fact there are three states that have not adopted the NEC.
The NFPA is the National Fire Protection Association, prepared and funded in part by insurance underwriters.
The fact that RVIA(RV Industry Association) has adopted the NEC as the recommended standard for electrical installations in RVs, it has no requirement that RV builders must follow the NEC. It is not a AHJ.
This LINK goes to one mans interpretation of what the Code is, you can accept it or reject it but it is accurate.
Additionally, the Code does not and cannot require the builder of a RV park to install RV pedestals or how many or what capacity it must install. It only covers what pedestals are acceptable to the NFPA.Additionally, the Code does not and cannot require the builder of a RV park to install RV pedestals or how many or what capacity it must install. It only covers what pedestals are acceptable to the NFPA.
If this is to far off course, the Mod or Admin should remove it, that is the way it works.
I hate to be contrary but, If the State/county/city has a building department that issues building permits and the
State has adopted the NEC building code then it must follow the NEC Artical Part VI #551.71 as to how many, what size and where the pedestals are installed. If not they will not issue a permit and the power company will not hook up. It's just the way it works.
