ggardne2
Aug 28, 2018Explorer
Can you describe the noise? Is it a whining noise or is it a clunk? If this is a deceleration whine it could be a driveline issue related to universal joints, an outboard wheel bearing on the axle, or potentially a transmission issue. If the differential hypoid pattern was OK I would tend to suspect a driveline angle/universal joint problem but would have expected the shop who worked on the differential to inspect the driveline as well.
Was the shop that worked on the differential an experienced driveline shop?
Having RV issues? Connect with others who have been in your shoes.24,397 PostsLatest Activity: Jun 29, 2026
