2oldman
Feb 05, 2014Explorer II
The only real danger I can see is overcharging. If you have a decent quality functioning controller, that will not happen. Be sure the battery water is up to level before leaving.
RoyB wrote:Would this happen by two wires crossing, or some other way?
all solar panel cables should be protected by high current fuses so that short circuits will blow the fuse
