mena661
Feb 05, 2014Explorer
BFL13 wrote:Thanks BFL. After reading that document, it does make sense with parallel strings to have fuses after a certain amount of strings to protect the wiring and panels themselves.
Here is the ref--wade down to the strings fusing part
http://www1.cooperbussmann.com/pdf/9df1f7ec-8c62-4210-8cf8-9504927394f0.pdf
Panel specs have a fuse size mentioned for that application "series fuse rating" eg my Sharp 130w says 15a and so does my Hanwha 230w panel have 15a for that.
( I am not sure all PWM controllers short the panels--the "shunt" type
do, but not sure about the "series" type.) You can short the panel no harm done.
