NRALIFR
May 08, 2020Explorer
The backside of the fridge (where the cooling unit is) is supposed to be completely sealed off from the living space, because of the possibility of a leak in the LP system. For that reason, yes it would be unsafe to remove that panel anytime the propane tank valves are opened. Regardless of which mode the fridge is running in (AC or LP) if the LP valves are open, the lines are pressurized and could leak.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
