wopachop
May 08, 2020Explorer
Old-Biscuit wrote:2013 Forest River Stealth model FS2812. (thats what the sticker on the window says...but searching always brings up FSC2812)
What model floorplan do you have?
Is anyone good at finding floor plans? I searched months ago and wrote forest river. THe previous owner said they moved the kitchen back 6 inches. Everyone is telling me noway. I just want to see the numbers so i can compare. My search tells me the cargo area is 144". But i measure 149" to the first cabinet. So it kinda matches what the couple told. Its a toyhauler and people make buying decisions on this number. Makes me think the listed 144" would be accurate.
Reason i mention is because my lower fridge vent sits right over the frame and is partially blocked. Will put up pictures later. Surely cant be helping my fridge work in hot weather.
Plan was to feed it cooler air from inside the cabin.
I understand now how the fan on the top exhaust is better, since you guys are saying you dont want air blowing direct on the big tank that im guessing is the part that purposely gets hot.
The roof vent has a cover. It must be designed to work properly in high winds? Its gets mega windy here. If i did have a propane leak i wouldnt want air coming in the top exhaust with enough force to then enter the trailer with my access panel removed.
New idea is maybe cut a small hole in the access panel to fit a fan. With hopes that air will only be able to travel one direction. So a propane leak could not enter the trailer with the fan running.
Shutting off the gas is no problem either. Its just me in here. I dont mine turning it on to cook and then turning it off. Maybe buy a secondary propane detector for the bathroom. Set it right there in the cabinet.
Having RV issues? Connect with others who have been in your shoes.24,396 PostsLatest Activity: Jun 24, 2026
