wa8yxm
Jan 19, 2016Explorer III
I have a much simpler version of that device.. I will describe.
First: I DO NOT have an Energy Manger (Load shedding type) so the wire goes direct from ONE circuit breaker to the A/C. (And from another to the other A/C)
At least that is the factory hookup.
Using 12ga wire (20 amp rated) for the 13.5 amp A/Cs. I found the lead to the REAR A/C.. And disconnected it from the power panel.. All 3 wires.
I then ran a brand new 12ga from the power panel, using the original breaker, to the outside of the RV where there is an outlet. This can be in most any non-wet basement compartment if you like.
I then ran a 12ga cord back to the back of the power panel where a Junction Box connects the new wire to the original.
IDEALLY (I did not do this) i would have put a 20 amp breaker in this final new line... I choose to trust the park's 20 amp breaker.
How it works
Plug A/C cord into outlet... Original setup
Unplug and using a 12ga Cord from Sears or K-mart with the push button on the outelt end.. Modified Rear A/C now runs on park 20
Side benefit.. Need air compressor on Driver's side.. I've an outlet.
How it works
Having RV issues? Connect with others who have been in your shoes.24,362 PostsLatest Activity: Mar 02, 2026
