MrWizard
Aug 17, 2015Moderator
Dutch_12078 wrote:
This cover should do the trick...
that was the first thing i thought of
but i don't think so
those are designed to also keep a toggle in the off position
installed on her monetary switch, it might keep the electric latch cycling/thumping
Description: It’s not what project you have in mind that may use a rocket launch switch… The question is what project will you come up with once you have one in hand? Everyone has a proverbial missile to launch.
The hot red safety cover protects a toggle switch from accidentally being turned on. When flipped up, the user has full access to a switch underneath. Upon closing the cover, the cover will force the switch arm back into the lower position - a safety mechanism so you can quickly hit the cover down and deactivate the switch.
this might turn into a yankee DIY design
Having RV issues? Connect with others who have been in your shoes.24,390 PostsLatest Activity: Jun 05, 2026
