jayfraze's avatar
jayfraze
Sagging Outer Walls/Compromised Interior Cabinets
Hi all,
I have been a long-time recipient of all the advice for repairing campers but this is my first post.
I have a 2006 Prowler Lynx 200XP by Fleetwood. Probably 75% of the floor is rotted or soft which is something I've dealt with before. My biggest problem is that the right side wall of the camper is sagging below the frame. Further, there is a crack in the frame with an attempted repair with a plate. I have not pulled up the floor yet but intend to as well as the kitchen cabinets. The sagging wall extends from the door to the rear of the camper, probably 12 feet at most.
I am wondering 1) are these things related? 2) how should I fix the sagging wall?
  • Gdetrailer wrote:
    You are better off to scrap a trailer with this much extensive damage, you can sell off things like windows ($200-$400), doors ($100 if not rotted), A/C $200 if working), furnace ($200 if working), water heater $100-$200), stove ($200).. You have potential of about $1500 you could get out of all the parts..
    Save yourself a lot of work, headaches and aggravation..
    Or, if you really want a project, go find a rotted box on top of a good frame, buy it at a bargain price, and rebuild with the windows and appliances of your current rig. I wouldn't personally be up for that level of a project at this stage of my life, but perhaps in retirement...
    In either case, I would not invest anything near that kind of money or time into a rig set on top of a cracked frame. That's just throwing good money after bad.
  • jayfraze wrote:
    Hi all,
    Do you "love" this unit?
    As they say with antique autos, it is a "labor of love"..
    At 75% of the floor soft or rotted, wall sagging below frame AND a previous repair to the frame, I really think you need to step back and perhaps go a different direction and find a trailer in far better shape.
    You are pretty much at the level of having to tear the entire trailer down to the frame and also toss the frame out.. Leaving you with pretty much nothing to work with.
    If you had a good solid frame you could have just removed the entire "box" and started a new box from scratch, but your new box is only going to be as good as that patched frame..
  • Hey Jay, welcome to the forum! Sounds like you got a pile of work ahead of you with this one. Prowler was a Fleetwood brand in 2006, so it's made just like my 2008 Terry was. I found a pic of a frame that is just like what Fleetwood used in that era:
    On top of the frame the floor platform is built with 2x3 framing and 1/2" flakeboard, and extends all the way out to the outriggers. Picture a floor platform running on top of the whole frame and out to the ends of the outriggers.
    Once the floor platform is framed, they roll out the sheet vinyl, add the base cabinets, then attach the walls on top of the floor platform (just like a house) and screw the walls to the cabinets.
    If the floor is that bad, then the baseplate of the wall is probably bad too, and the wall is sinking down between the steel outriggers. Unless those are rusted off, in which case there is nothing but the cabinets holding that wall up.
    Hopefully the vinyl floor prevented the cabinets from soaking up that much water, so if you can save the cabinets you'll be money ahead. Get the cabinets and appliances out of there ASAP, Then tear what's left down to the frame and start with a fresh floor and build up like they do at the factory. Big project but do-able if you have the time.
  • If you want a project, go for it. If you want to go camping....
  • Sagging wall and soft floor are both likely caused by (a lot of) water intrusion, assuming the wall is wood framed. Wall repair is conceptually akin to floor repair, just vertically rather than horizontally: remove all the rotten skin, framing members, etc., and replace. It's not a quick Saturday afternoon job!
    Basically, it sounds like you'll end up rebuilding half a camper...one with a frame that may be questionable. I'd think long and hard about cutting my losses before diving in; but on the other had, if it's the kind of work you enjoy doing as a hobby, perhaps it's worth the effort. It might not be much harder, though, to get a box truck or a step van or a bus or something and build up a new RV in that, reusing appliances and fixtures scrounged from the trailer.
  • Sad to say, but that Prowler is probably not worth repairing. Almost invariably, water & rot damage is far more extensive than is apparent.
  • Frame patches, rotted floor, sagging walls.
    Wow, you certainly don't run from a challenge.
    My question....is it worth it ?
Having RV issues? Connect with others who have been in your shoes.24,288 PostsLatest Activity: Jan 09, 2022
