Ltrip's avatar
Ltrip
Sagging springs on 2 yr old TT ??
I took our trailer to a shop for a wheel bearing repack. They have done work for me before and have good ratings. I think I can trust them.
As part of the service, they checked the springs. They said the springs were sagged out of spec and need to be replaced.
The trailer is 2 years old and I have about 10,000 miles on it.
I am skeptical.
I have a 2018 Arctic Fox 25Y TT. GVWR = 10,000lbs. Net carrying capacity = 3147 lbs.
No, I have not weighed it loaded as we normally load it.
It is my wife and I...no kids or pets.
I find it difficult to imagine that we load 3000 lbs into the trailer.
Does this sound possible? Sagging springs after 2 years and 10k miles?
I have an extended service contract. I have not asked yet, but is something like this normally covered?
Thanks!
  • ppine's avatar
    ppine
    Explorer III
    AF is a great brand with a lot of carrying capacity. Unless you have been collecting rocks and bringing your tools, get another opinion.
  • This issue has become more and more common with both Lippert and Dexter suspension systems. The cause is rooted in the use of inferior quality steel for the springs (possibly from China). If the springs have anything other than an elliptical shape, there is an issue. If the springs have flattened, you certainly want to replace them (with something other than Chinese steel) before you have one break and do damage. This has nothing to do with Northwood quality as they are vendor-supplied parts.
    Rob
  • “I honestly wouldn't worry about it. I'm guessing the shop is trying to make more money off you.“
    I would. Guessing can get expensive. Have your extended warranty provider check it. That “covers” you should something happen since you now have knowledge of a possible issue. Keep the paperwork!
  • Yep, my springs on a nearly new Coleman, since traded. After a 5200 mile trip last year I found damage to the bottom above each tire. Local tire shop ordered uograde springs, made in the USA, from these guys. Raised the trailer, more curve, so I had to adjust the WD hitch. Search the "Bottom damage" thread.
    http://www.aaaspring.com/
  • I would be skeptical too, very skeptical.
    Arctic Fox is a good brand and known for quality.
    However, having said that, they don't make the springs themselves, they likely outsource them from who knows where.
    2 years old, I would contact Arctic Fox and explain the situation to them and respectfully request input before just going with one shops diagnosis. At the very least, get a second opinion.
    No way I would just put new springs on a near new trailer.
  • I've been around Northwood forums for many years and have NEVER heard of springs sagging.
    Never heard of it on Dexter Axles either.
  • Sounds unusual. I looked the Artic Fox years ago but considered it way too heavy for my needs.
  • Yes, it is possible. Posting a photo and let us see the springs in question. If a spring has a noticeable flatness or reverse bend, it is bad. The quality of suspension components on trailers is poor.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 24, 2025
