A1RVTraveler
Oct 17, 2018Explorer
It all depends on the installation. If you have an outside access door to work on the furnace, you can remove the fan cover and replace the sail switch. If your furnace is installed from inside the RV and only the intake and exhaust pipes are visible from the outside of the RV, you will need to pull the furnace to get to the sail switch.
Having RV issues? Connect with others who have been in your shoes.24,413 PostsLatest Activity: Sep 15, 2026
