wa8yxm
Dec 06, 2020Explorer III
It should be zero but your meter is what we call a high impedance load (means it is a very tiny load) so if there is any leakage due to moisture on the wires, or perhaps a leaky transistor on the control board it will detect SOME voltage.. I doubt 2 volts is a problem (but may be wrong)
It is possible you have a control board problem... But you are not yet at diagnostic level IF, and I stress IF, you have a control board problem may I recommend Dinosaur boards.. Very well built.
Having RV issues? Connect with others who have been in your shoes.24,361 PostsLatest Activity: Feb 21, 2026
