2oldman
May 11, 2013Explorer II
smkettner wrote:It is in the inverter - at the socket. If I'm seeing it right, you can see the white and green wire connected together at the socket in the picture above.
I thought ground should be bonded, not switched.
I did connect the Romex ground to the inverter case as directed, and the Rv's panel has a ground wire also as does the shore power cable.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
