BFL13
Jul 07, 2021Explorer II
It shows that your battery bank (as entered in AH for capacity at the 20hr rate) will only last half an hour at 124 amps draw. After the MW has run its five minutes or whatever. the battery bank will bounce back quite a ways and still give you lots of time at ordinary amp loads like 10 amps for the furnace and a light.
Your idea of battery voltages seems muddled. Your converter is set at 14.6 but the battery will take time to reach that voltage (Bulk Stage) then it is still not full. Now it stays at 14.6 with amps tapering until the battery is full. Now you drop that voltage to 13.6 for floating.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
