EMD360
Jul 07, 2021Explorer
Right I may be muddled. I have read that explanation of battery charge and I must not fully understand it. The RV is usually plugged in to a 20 amp outlet with a 40ft outdoor extension cord. I think it’s a 14ga. So since it’s been constantly plugged in the charger should be in float mode and the battery somewhere between 13.8 and 14.6. I believe 13.8 is the highest voltage I’ve seen on the meter. I started the inverter just after disconnecting shore power and the meter only read 13.37 which seems a little low.
27 min left using the microwave would be great but the time left was dropping like crazy while the micro was on. From 9 hours to 27 min in a minute. I guess I should test again using the microwave until the battery power drops below11 amps. I thought that I could use the microwave with the inverter for short bursts of time without pulling that much power.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
