time2roll
Jul 07, 2021Nomad
I still recommend 400+ amp hours for an inverter of that size. Victron seems correct. Although is it set for LFP? If set to lead-acid the Peukert calculation will reduce the expected capacity a bit faster. Did I miss the battery set up?
Otherwise seems normal.
Could be the photo angle but the ventilation seems a bit tight.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
