theoldwizard1
Jul 07, 2021Explorer II
ktmrfs wrote:
batteries 12V in parallel, or GC2? GC2 do NOT like high current draw, way to much internal resistance so the inverter will kick out on low voltage pretty quick.
12V, assume you have at least 2, they (a) share the current, so each battery supplies 1/2 the load current unlike a GC2 pair where each battery must supply total load current and (b) have much lower internal resistance, hence less voltage drop with high current load.
I disagree completely !
Golf cart batteries are designed specifically to handle "high" loads and at 125A that is only 1/2C ! A pair of GC-2 batteries will live longer than a pair of 12V marine/RV batteries and cost less !
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
