time2roll
Jul 09, 2021Nomad
EMD360 wrote:The label says 900 watts output or cooking power. Add 30% to 50% for input power. Then you lose 10% in the inverter converting from battery power.
The idea of replacing the micro with a low draw is interesting. The one I have is rated at 900 watts (1.35 kw power consumption) but from the inverter it drew much more. I could try it at 50%.
I doubt that HighPoint will reduce power at a lower setting. Probably just cycles the megatron at full power.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
