EMD360
Jul 09, 2021Explorer
Itinerant1 that is a lot of battery power! Love the spreadsheet I’m going to look at it more closely. What device do you have that records that info?
I rechecked the BMS on the LIoN Safari batteries and it does shut them down when outside the temperature range. It was in the question and answer info I didn’t see it in the specs.
“The Safari UT already has an internal Battery Management System (BMS) that acts as a safety net to shut down the battery if it is out of parameters. This prevents the battery from overcharging or discharging as well as operating outside of the temperature range.”
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
