Itinerant1
Jul 12, 2021Explorer
You're using LFP so the SOC or "I’m curious if the fully charged battery can take more inverter load" doesn't really have an effect the way I think you're thinking that lead does, but when the lvd (low voltage disconnect) is reached it will shut itself down.
As an example the other day I turned the A/C on when the the SOC was 60% and ran it till 35% (near 2 hours) so it was inverting at 140a +/- for a couple hours, the inverter was showing 12.2v before I shut it off. If I kept it going the inverter would of shutdown at 12.0v probably in another hour or so.
Edit.. the inverter will shutdown before the batteries have reached the lvd (vpc). The charge/ discharges source should be setup to disconnect before the battery bms does the shutting down.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Sep 01, 2026
