Ralph_Cramden
Oct 01, 2017Explorer II
dave17352 wrote:
You can't run it of a split signal. Take the split er out that runs to other outlets. If I recall correctly that is the problem.
Yes you can but the splitter must be a "power pass" splitter and the RV manufacturers do not know what one of those is because they cost fifty cents more.
As also said, satellite signal and power will not like, nor pass through, the antenna power supply either on or off.
Rockwood got it right on our 2017, well sort of as all the connectors were loose and installed by a 3 yr old. It has two connections outside marked sat and cable. Cable is a home run to the antenna power supply cable in port. Sat is a home run to a power pass splitter, then to seperate connections at TV's.
Having RV issues? Connect with others who have been in your shoes.24,374 PostsLatest Activity: Apr 06, 2026
