CarnationSailor's avatar
May 23, 2021
Satellite Pre-Wiring
I have a 2015 Crossroads Rushmore Springfield and am trying to understand how it is pre-wired for satellite. (I want to add an RF Mogul Eagle permanent-mounted antenna on the roof and connect it to a Dish Hopper 3 receiver.)
There are 2 coax jacks on the roof. Does one go to the entertainment center and one to the bedroom?
In the entetainment center, there are 3 coax cables in the cabinet above the TV. I assume one would attach to the receiver's input, but since the receiver's output is HDMI, what are the other 2 used for? (Maybe back in 2015 the receiver's output would have been coax?)
There are 2 coax connections behind the TV. One goes to the antenna/cable TV input. Was the other intended to connect the TV to the satellite system? That is, does it connect to one of the 3 coax cables in the cabinet above?
In the bedroom, there are 2 currently-unused coax jacks. Are they part of the satellite system pre-wiring. (Neither the jacks behind the TV or in the bedroom are labeled.)
Any thoughts on this will be appreciated.
Thanks
  • LouLawrence wrote:
    Sounds like you installed a dome and not a Trav'ler. What was your final setup?
    I did not install a dome or a Trav'ler. I had a dealer install an RF Mogul Eagle which is very similar to a Trav'ler.
    IT worked great immediately after installation, but I had problems "acquiring a signal" the first time I moved to another location. Many support calls to Dish before finally getting a tech that identified the problem. The problem was the pre-wired coax that was used to connect the antenna controller to the receiver.
    Instead of trying to get the bad coax replaced which would have been difficult and expensive, I ran a coax inside the trailer from the cabinet at the rear of the trailer where the controller box was located to the slide out with the entertainment center and Dish receiver. The cabinet and the entertainment center are only about 4 feet apart so I was able to do a neat run of the coax, and I left a loop of extra length that allows the slide out to move in and out without stressing the coax.
    So far, so good.
  • HD and multiple channel reception (My DTV records 5) require better coax and connectors - ie less loss and higher bandwidth. This is for better reliability. If by dealer you mean RV dealer then I'm not suprised.
    I'm curious: Was the prewire adequate for the power wires to the dish?
    The installation was done by a Dish Network dealer that was an authorized installer of the RF Mogul antenna. He ran a new coax from the antenna thru the roof to the controller inside the rear/upper cabinet. He also connected the antenna to the controller with the multi-wire cable that provides power and control signals to the antenna.
    To get the satellite signal from the controller to the receiver, he ran a new coax back up thru the roof to a pre-wired coax jack whos associated coax cable ran to the entertainment center where the receiver was located. (With the RF Mogul system, the satellite signal passes thru the controller to the receiver.)
    He initially detected that the pre-wired jack was seriously corroded so he replaced it. When he checked out the installation, the system worked fine. (I don't know that he actually measured the quality of the signal going to the receiver. The system worked so apparently all was good.)
    However, the problems I experienced where sometimes the receiver could acquire the signal and sometimes it couldn't, eventually lead to my running a new coax directly from the controller to the receiver (bypassing the pre-wired coax), and the problem went away.
Having RV issues? Connect with others who have been in your shoes.24,188 PostsLatest Activity: Jan 19, 2025
