CarnationSailor's avatar
May 23, 2021
Satellite Pre-Wiring
I have a 2015 Crossroads Rushmore Springfield and am trying to understand how it is pre-wired for satellite. (I want to add an RF Mogul Eagle permanent-mounted antenna on the roof and connect it to a Dish Hopper 3 receiver.)
There are 2 coax jacks on the roof. Does one go to the entertainment center and one to the bedroom?
In the entetainment center, there are 3 coax cables in the cabinet above the TV. I assume one would attach to the receiver's input, but since the receiver's output is HDMI, what are the other 2 used for? (Maybe back in 2015 the receiver's output would have been coax?)
There are 2 coax connections behind the TV. One goes to the antenna/cable TV input. Was the other intended to connect the TV to the satellite system? That is, does it connect to one of the 3 coax cables in the cabinet above?
In the bedroom, there are 2 currently-unused coax jacks. Are they part of the satellite system pre-wiring. (Neither the jacks behind the TV or in the bedroom are labeled.)
Any thoughts on this will be appreciated.
Thanks
  • Even if Crossroads gave you a wiring diagram there's no guarantee it's accurate. If there's one thing RV manufacturers are known for, it's their lack of consistency. I'd fabricate some shorting connectors and ohm-out the cables (and hope there's no DC blocking components in between).
    It took us a bit of time to ohm-out our truck camper's OTA/cable wiring in order to install a Dish satellite system.
    Good luck.
  • Unfortunately you'll have to short each cable at one end, then use your voltmeter to check for 0 ohms at the other end.
  • You may be able to obtain a wiring diagram from the coach maker.
    Failing that trial and error is your only real option.
    In our coach which is n old 1998 Dutchstar everything was labeled from the factory so it’s quite simple to figure things out.
Having RV issues? Connect with others who have been in your shoes.24,336 PostsLatest Activity: Nov 16, 2025
