CarnationSailor's avatar
May 23, 2021
Satellite Pre-Wiring
I have a 2015 Crossroads Rushmore Springfield and am trying to understand how it is pre-wired for satellite. (I want to add an RF Mogul Eagle permanent-mounted antenna on the roof and connect it to a Dish Hopper 3 receiver.)
There are 2 coax jacks on the roof. Does one go to the entertainment center and one to the bedroom?
In the entetainment center, there are 3 coax cables in the cabinet above the TV. I assume one would attach to the receiver's input, but since the receiver's output is HDMI, what are the other 2 used for? (Maybe back in 2015 the receiver's output would have been coax?)
There are 2 coax connections behind the TV. One goes to the antenna/cable TV input. Was the other intended to connect the TV to the satellite system? That is, does it connect to one of the 3 coax cables in the cabinet above?
In the bedroom, there are 2 currently-unused coax jacks. Are they part of the satellite system pre-wiring. (Neither the jacks behind the TV or in the bedroom are labeled.)
Any thoughts on this will be appreciated.
Thanks
  • Even if Crossroads gave you a wiring diagram there's no guarantee it's accurate. If there's one thing RV manufacturers are known for, it's their lack of consistency. I'd fabricate some shorting connectors and ohm-out the cables (and hope there's no DC blocking components in between).
    It took us a bit of time to ohm-out our truck camper's OTA/cable wiring in order to install a Dish satellite system.
    Good luck.
  • Unfortunately you'll have to short each cable at one end, then use your voltmeter to check for 0 ohms at the other end.
  • You may be able to obtain a wiring diagram from the coach maker.
    Failing that trial and error is your only real option.
    In our coach which is n old 1998 Dutchstar everything was labeled from the factory so it’s quite simple to figure things out.
