Macrosill
Jun 01, 2013Explorer
'tiredTeacher wrote:K Charles wrote:
The satellite hookup on the outside of your TT is for satellite TV not satellite raido,
I know that. I'm not an idiot.
Maybe I'm not explaining this well. I want to use the satellite TV cable because it runs from the outside to the inside. I don't have satellite TV so the cable isn't hooked up to anything inside, it just terminates at the telly. I want to plug my satellite antenna to the outside male cable terminal and use the inside end of that cable to plug into my XM.
This will negate having to run the antenna out through a window or past a slide seal.
I hope oit makes more sense now.
Teach
With some adapters I am sure it could be done. The only concern would be about the cable mismatch. RG6, the sat tv cable, is a 75ohm cable. I am not sure but I would suspect the sat radio antenna cable would be a 50ohm cable. Might get some signal loss by using the RG6 for the antenna connection. But this is just a guess. Try it and see how it works. It should not cost too much to try.
Having RV issues? Connect with others who have been in your shoes.24,410 PostsLatest Activity: Aug 30, 2026
