Almot
Aug 10, 2014Explorer III
BFL13 wrote:
... if you only had one monitor it should be the Tri and it is the solar monitor that is of limited use.
Same old again...
1) Yes.
2) Not really.
In more details:
If you have right size of solar, so that it brings batts to Float every day or most of the days, a solar monitor will tell you this, and this is all you need to know. Trimetric would be of limited use then. Other than the described above investigative analysis of improperly done wiring :)...
If you can't charge your batts fully with solar, or don't need to, then you do need a Trimetric, and then solar monitor would be of limited use.
Having RV issues? Connect with others who have been in your shoes.24,389 PostsLatest Activity: May 22, 2026
