bucky
Nov 15, 2014Explorer II
I had to call Scanguage to get the right code to load as the correct one was not pre
programmed for a 98 Chevy.. They were very helpful. As long as a signal is being sent to your PCM for temp, you should be able to pull it after the scangauge is loaded properly.
