Pool
Jun 01, 2013Explorer
Trans temp
I watch the Trans temp while towing and curious what a good range is to make sure it is not too hot. I have a factory front mounted trans cooler on a four speed 5.3 engine. Normally runs about 176 - 182.
Tow later wrote:
We are new to camping and purchased a Crossroads 27' Zinger 27RL, we also have a 2010 Chevy Avalanche 1500LT. We went camping last week and pulled the trailer approximately 200 miles and I noticed my trans temp was running between 198 and 205 degrees.
Also the truck is rated to pull 8100 lbs, and the trailer is rated at 7850 lbs, I have installed a Reese Weight Distribution Hitch with Sway Control but the trailer dances and porpoises all over the place. I had the trailer set up by camping world and they said everything was right. I was informed by another RV service center that part of my problem was the Avalanche has coil springs and they suggested installing air bags as well. We are now considering purchasing a 2013 Chevy Silverado 1500HD with the all star package on it. We Sally don't want to spend the money on a new truck right now so any suggestions would be appreciated.
USMarine0369 wrote:Cummins12V98 wrote:USMarine0369 wrote:
I have a heavy duty transmission in my Ram with a 91% lock torque converter and low stall. In stop and go traffic mine will reach 200. Once I move it goes down, but in the city on hot days it will stay between 140 and 180 depending on my movement.
I installed a fairly large 2nd cooler in line with the factory one. I don't know why the Chevy guy would tell you that is a bad idea. You might want to bypass your factory cooler and just use an external one, as I think your factory cooler is routed through your radiator.
I also run Amsoil ATF in it and change it about every 16-20,000 miles.
You should look at your radiator and see if it is plugged up with road grime.
I'll try and post a pic of what mine looked like before I cleaned it out.
I am guessing by your pic you have a 2nd gen 24V.
Go thru the factory cooler first then the added cooler that way the oil get's warmed up.
I do. I went through the heat exchanger, the stock cooler, and added a cooler.
