opnspaces
Mar 24, 2020Navigator III
At this point don't worry about trying to correct the old post. But in this new post you can just use the "Reply" button and add more information to help us help you.
What we really need to know is in your words what happens when you try to start the motor home?
When you turn the key do the dash lights come on?
If you turn on the dome light and then turn the key to start does the dome light go out?
When you turn the key to the start position do you hear any noises or clicks?
If you hear a click do you hear a single click or a series of clicks?
Do you hear the engine crank over but it does not start?
Does the engine crank speed sound sufficient to start? Or does the cranking speed seem low?
If you hear any other noises can you try to describe them and when they happen?
