road_warriors's avatar
Mar 23, 2020
sceamig help for my 2000 rexall airbus
so sorry to everyone who replied and thank you for replying. I did a very poor job in posting my last post. I started with my water heater then jumped off track. I did finally call an R.V. mechanic for the house side of my R.V and after I had changed everything having to do with the heater it turned out to be a corroded wire from the darn propane tank safety valve. Now, the rest of the story. When I began working on the w/h my r.v. would run. Its a 2000 Rexall Airbus with the V-10 Ford engine. Gas type. 36 footer. But for some reason, now it won't start. So I naturally figured that I may have shorted something, fuse, relay, or made a horrible mistake. As it turns out the chassis side is totally different from the house side so it is improbable that my fear most likely is not the cause. Sooooo, I would still appreciate any help or suggestions that any of you may have. Again I am very sorry for my bad attempt to post. I did realize that I gave little info on my r.v. but I didn't know how to go back to my post and correct it. Thanks again
  • Details, we need details. :)
    When you say it doesn't run do you mean it won't turn over, it clicks when you try to start it or it does nothing when you try to start it?
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Mar 27, 2025
