tvfrfireman wrote:
newman fulltimer wrote:
your inwall wire is more than likely pinched when the rails got changed.
The wires are not pinched. They travel down inside a rubber piece and can't get pinched. I can see the wires at the bottom go under the slide. These wires were all tested. When the slide is halfway out you can visually see them where they make their turn from vertical to horizontal. I hope someone who had the same problem will chime in. Thanks for reading and your suggestions.
you can say no no no all you want it is 1 a pinched wire 2 wire connector bad 3 motor bad ...
