dougrainer
Oct 25, 2020Nomad
craigandsue wrote:
Spoke with the tech again and he said he checked all the connectors but the slide out is still acting up. Sometimes the rear stalls, sometimes the front. He is going to get another set of eyes on it to see if he's missing something. I noticed the new 2021 model year does not use Schintek in the large kitchen slide out.
He checked it again. DID HE CHECK FOR ERROR CODES????????? IF NO error codes, the next procedure with Jayco approving is to take BOTH outside wall flanges loose(with room extended about 12 inches) with a lift supporting the room and let the Schwintek mechanism mount self center and then reattach the outside flanges even IF the holes do not line up. When you have stall and NO error codes that usually means the complete room/mechanism is binding. This procedure fixes that. If the holes still line up, the room was installed correctly. Doug
Having RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 13, 2026
