BayouBoys's avatar
BayouBoys
Schwintek Slide Problem
On a routine check of my RV, the slide won't go out. It is the Schwintek type slide. I have already read through all the manual & bulletins and watched their youtube videos. I have tried everything they suggested and nothing is working.
When I press the button, I hear both motors whine for a few seconds then stop, so I know the motors are getting power. The controller is giving me a code 8 & 9. If the controller were not getting a signal then the motors should not do anything (code8). If there were a short in the wiring, the fuse would blow and the motor would not do anything (code9).
I bypassed the limit switch just to get things moving and nothing happens. I have released the motor brakes and the slide will not budge. The slide is in the closed position and I can't get at the motors.
Any suggestions? BTW it is out of warranty and the dealer can't fix a leaky faucet.
  • I suggest that if you have released the motor brakes and the slide "will not budge", it's not a problem with you Schwintek. It sounds like your slide is physically jammed.
    Are you trying to actuate the slide without the trailer being level?
  • I got sick and tired of the intermittent slide problems w/ all the safety devices. etc etc. and thanks to the help of a slide "RV tech" here, I installed a little push button on the dash, (grounds the solenoid) and whenever it fails (50% of the time) to slide, I give it the push button treatment, and it has never failed again, in over a year.
    Yours being a R&P drive??, may be a whole different story.
Having RV issues? Connect with others who have been in your shoes.24,343 PostsLatest Activity: Dec 16, 2025
