DO_N_DAT's avatar
DO_N_DAT
Screen removal for cleaning
Wanting to remove screens for cleaning but, haven't figured out how to do it. Don't want to put too much stress on it and risk damaging them. Any advise?
Here is a picture of one of the screens. The screen is all the way down.
  • Most usually just push up against 2 springs until it is high enough to remove from the bottom. Just a hint, open the sliding window first then slide the screen open about 4 or 5 inches, then put upward pressure on the screen frame, either on the top of the frame or wherever, keeping in mind you have to compress 2 springs in order to get the screen high enough to remove the bottom.
  • Usually just push up and lift out from the bottom.
    I use a small vacuum clear with a hose on it. Sometimes one of those Micro Fiber towels. Than you do not have to remove them.
Having RV issues? Connect with others who have been in your shoes.24,344 PostsLatest Activity: Dec 22, 2025
