Just replaced an outside marker light, but the screw was not able to grab (because the hole was too big). What is the best way to repair this? Thank you.
There are many ways to skin the cat here with the obvious being can you use a larger screw - say move up from a #8 to a #10. So beyond the obvious there, what's your marker mounted to? For instance, aluminum siding or composite wall camper?
