Just replaced an outside marker light, but the screw was not able to grab (because the hole was too big). What is the best way to repair this? Thank you.
If wood, a common fix (assuming just wallowed out, not rotted out)is to insert a couple of wood matches (sans head) into the hole. Be sure to put some sealer on the screw threads before threading it in.
