wsac5erExplorerJan 19, 2015Screw Hole Too BigJust replaced an outside marker light, but the screw was not able to grab (because the hole was too big). What is the best way to repair this? Thank you.
Roger10378Explorer IIJan 20, 2015In sheet metal I use a cotter key. Slide the two legs on either side of the metal sheet with the head in the hole.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
Related ContentStripped screw holesRemoving Dicor from screw holes...Repair stripped screw holes in fiberglassFilling screw holes in roofPatching screw holes in ceiling?
