wsac5erExplorerJan 19, 2015Screw Hole Too BigJust replaced an outside marker light, but the screw was not able to grab (because the hole was too big). What is the best way to repair this? Thank you.
pianotunaNomad IIIJan 20, 2015Hi,Size the hole by stuffing it with Kleenex or similar. Add some drops of water thin CA glue. Let it cure before inserting the original screw.Dowel, match sticks, or toothpicks have the wrong grain. Don't expect such a fix to hold well.
About Technical IssuesHaving RV issues? Connect with others who have been in your shoes.24,412 PostsLatest Activity: Sep 09, 2026
Related ContentStripped screw holesRemoving Dicor from screw holes...Repair stripped screw holes in fiberglassFilling screw holes in roofPatching screw holes in ceiling?
