Just replaced an outside marker light, but the screw was not able to grab (because the hole was too big). What is the best way to repair this? Thank you.
Well if the hole is to bad for the match sticks to work. Get a wooden dowel pin from hardware store. Very carefully drill out the screw hole insert the dowel pin with epoxy or waterproof glue. Pre drill the dowel and insert the screw. Pre measure the pin so it is flush with the surface. Yes it sounds complicated but it will make a permanent repair. Bill
